I thought I would share what I found out about the wiper spindle's bushes.
Outer Wiper Spindle Bush/Seal:-
Inner Diameter: 16 mm
Outer Diameter: 24 mm
Height: 8 mm
Inner Wiper Spindle Bush:-
Height: 8 mm
Anyway, as I found out that I could not get the original bushes anymore, I had to do some digging around on eBay and Grommets limited (they are currently closed until 6th Jan 2014).
Outer wiper spindle bush nearest equivalent (eBay):-
http://www.ebay.co.uk/itm/290913649863?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Outer Diameter: 28 mm
Height (widest part): 5 mm
Overall height: 9 mm
Inner wiper spindle bush nearest equivalent (eBay):-
http://www.ebay.co.uk/itm/200962749930?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Outer Diameter: 27 mm
Height: 18 mm
Other bushes are also available from Grommets limited (minimum £30 order excluding VAT and excluding postage) within their outer diameter 19 mm to 75 mm section http://www.grommets.co.uk/bushes-standard/
