I need information on the heater fitted to the Fox. It is different to the 3-wheeler version. Mine has hot water going in but no hot air coming out (the fan does work). Also the front wheel brake adjusters are giving up the ghost. Do mini adjusters fit?
kg4gp
Posts : 23 Join date : 2011-08-19 Age : 32 Location : Land of Beer and Marmite, home of the Jaffa Cakes
Subject: Re: FOX MATTERS Fri Oct 10, 2014 8:09 am
I have this same problem with my kitten, Hot air in but always cold or outside temp that comes out the heat the fan is working on mine too .
mechanicalhorse
Posts : 14 Join date : 2014-08-08 Age : 61 Location : Wakefield
Subject: Re: FOX MATTERS Fri Oct 10, 2014 10:06 am
The Kitten and Fox heaters are better than the 3-wheeler ones because the hot water is always going round the heater unit (ie not controlled by a valve, as on Robins etc) so I think the problem may lie in the linkage that controls the flaps. Do you get hot air coming out of anywhere (the upper vents for example)?
