 Fox heater
Tony Guest
PostSubject: Fox heater   Wed Oct 08, 2014 4:13 am
The heater in my Fox has packed up. Hot water goes in (and out) but hot air doesn't come out. Fan works. Where can I get a replacement?
Fox heaters are not the same as those on 3-wheelers.
Can the heater be rebuilt?
Tony Guest
PostSubject: Re: Fox heater   Wed Oct 08, 2014 6:55 am
I also need information about brake adjusters. Will mini ones fit?
mechanicalhorse
PostSubject: Re: Fox heater   Wed Oct 08, 2014 11:44 am
Rear brake adjusters are the same as Mini ones. If it's the front ones you require then everyone will say you can't replace them and you need new backplates (which come complete with adjusters) - but actually they can be replaced by grinding off the retainers on the outside and then fitting these:
http://www.ebay.co.uk/itm/AUSTIN-MINI-1964-1984-ONE-FRONT-BRAKE-SHOE-ADJUSTER-BBA101A-/261612649193?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ce9543ae9#ht_5605wt_1056
Tony Guest
PostSubject: Re: Fox heater   Thu Oct 09, 2014 2:09 am
Thanks, I now have some front wheel brake adjusters on order.
Would like to get the heater fixed before the weather turns really nasty.
Admin
Admin
PostSubject: Re: Fox heater   Fri Oct 10, 2014 8:07 am
Is the heater the same as the one in the kitten?
View user profile http://reliant.forumotion.co.uk
Rebellion
PostSubject: Re: Fox heater   Thu Nov 13, 2014 10:10 am
Yes, and Triumph Dolomite among other cars that it fits. Cool
Fox heater
» Heater for the RZR
» Adding Heater
» New Cab Heater
» Cab Heater
» RZR Heater For sale
Reliant Central  :: Reliant 4-wheeler-
