| My Kitten | |
Author | Message |
kg4gp
Posts : 23 Join date : 2011-08-19 Age : 32 Location : Land of Beer and Marmite, home of the Jaffa Cakes
| Subject: My Kitten Wed Oct 24, 2012 7:20 am | |
AMAM
Posts : 72 Join date : 2011-08-19 Location : wakefield
| Subject: Re: My Kitten Thu Oct 25, 2012 5:44 am | |
| i'l have to have a look in garage for some wheel trims/hubcaps for your kitty | |
Bill Bailey
Posts : 112 Join date : 2011-08-19 Location : Outside your window.
| Subject: Re: My Kitten Thu Oct 25, 2012 10:17 am | |
| - AMAM wrote:
- i'l have to have a look in garage for some wheel trims/hubcaps for your kitty
I've been using them as frisbees in my cellar lol. | |
kg4gp
| Subject: Re: My Kitten Wed Aug 14, 2013 9:31 pm | |
| My kitten passed her MOT on Monday | |
Emma K
Posts : 13 Join date : 2014-07-30
| Subject: Re: My Kitten Tue Aug 05, 2014 6:37 am | |
| Congratulations on the MOT. Did you fit the blue door? If yes any problems and what was the donor car?
(I am collecting my kitten on the 15th August) | |
kg4gp
| Subject: Re: My Kitten Tue Aug 05, 2014 7:41 am | |
| Unfortunatly i didn't fit the blue door it was done by one of the previous owners, it seems my kitten was thrashed around a farm for a while before i got it, shes got alot of war wounds.
The front doors fit fine, there doesnt seem to be any issues with them fitting, and I can't see any alterations, the donor car i think was either a robin or rialto .. but the bonnet and rear door have also been replaced at some point .. | |
Emma K
| Subject: Re: My Kitten Tue Aug 05, 2014 11:54 pm | |
| Thrashed round a farm... sounds familiar. The farmers boy next door wants to buy my Robin for a bit of fun :-( Anyway;
Thanks for the info and quick response. | |
AMAM
| Subject: Re: My Kitten Wed Aug 06, 2014 9:50 pm | |
| - Emma K wrote:
- Thrashed round a farm... sounds familiar. The farmers boy next door wants to buy my Robin for a bit of fun :-( Anyway;
Thanks for the info and quick response. a kitten and mk1 use thinner less heavy duty hinges than the rialto and later robins, you cant find a rialto/robin door using the hinges off them you have to use the mk1/kitten hinges to make it work | |
Emma K
| Subject: Re: My Kitten Thu Aug 07, 2014 4:57 am | |
| Thank you for that pointer.
The front edge of the drivers door on the Kitten has been rivetted to the inner moulding and it is not lining up when closed. The storm wind caught my Robin's door in November and overstrained it causing some audible cracking (ouch) and it now hangs about 3 -4 mm low at the back edge.
Once I have the Kitten home I can assess it then tackle the better least work/expense car first. If it is possible I will try and get the Kitten back on the road before the winter.
I guess I am going to get good at removing, repairing and refitting doors! | |
AMAM
| Subject: Re: My Kitten Thu Aug 07, 2014 9:49 pm | |
| - Emma K wrote:
- Thank you for that pointer.
I guess I am going to get good at removing, repairing and refitting doors! kittens are double skinned compared there 3 wheeled counterparts, I have seen kittens before where the skins have split and people have riveted them back together, it doesn't last as the rivets pull through, needs fiberglassing or another door most people get two rialto doors off a scrap car or something | |
Emma K
| Subject: Re: My Kitten Sun Aug 10, 2014 6:56 am | |
| OK. Thanks again amam. I learn something new each day | |
AMAM
| Subject: Re: My Kitten Wed Aug 13, 2014 3:16 am | |
| - Emma K wrote:
- OK. Thanks again amam.
I learn something new each day I found that out myself the hard way, spent a couple of hours struggling to fit new hinges to my old kitten passenger door..... ....only to then find out I couldn't shut the door cos they are so thick they push the door to far back to close lol | |
Emma K
| Subject: Re: My Kitten Wed Aug 13, 2014 7:04 am | |
| Ouch! The problem with experience is that you have to have it before you can learn from it. | |
kg4gp
| Subject: Re: My Kitten Tue Aug 19, 2014 9:55 pm | |
| Yey my speedo cable is here | |
| Subject: Re: My Kitten | |
| My Kitten | |
