Would you like to react to this message? Create an account in a few clicks or log in to continue.
HomeLatest imagesSearchRegisterLog in
 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)
Go to page : 1, 2  Next
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) Empty
PostSubject: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:07 am
Some of you may have seen various threads in various places (and in one of this year's ROC National magazines) about my Rialto SE. My Rialto SE is my very first 3 wheeler that I have ever had and (believe it or not) I have never set foot in a 3 wheeler until T.E.L.B.O.Y. gave me a lift in his mk3 Robin in February 2010.
Anyway, I will try and summarise what I did to my Rialto SE.
How I got it on 10th April 2010
My Rialto SE as it was advertised and how I got it on 10th April 2010 (I looked at it on 5th April 2010) from Dressmaker (ex ROC member) in Southampton:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) Image099dressmaker
I got the car for £200 (it sounds cheap now) with tax and test, but it's clutch and thrust bearing needed to be replaced immediately. Thankfully, thier local garage and MOT station (L D Stanley) was only about 200 yards away from their house. I got the clutch and thrust bearing from sparesman and got L D Stanley to fit them.
About 6 hours later, the car was ready and I set off on the 100 mile trip home from Southampton. About 500 yards into the journey, the gauges, wipers and indicators fuse blew and it started to rain ! Thankfully, there was a Shell garage as that fuse went, so I quickly pulled in and found some spare fuses in the ash tray. I quickly changed that fuse and got the car home.
As the engine warmed up, I noticed a slight knocking noise (it been there ever since) but it didn't sound like anything nasty. I did pull into Fleet services on the M3 just to quickly check the car. At the time, I thought that it was low on oil and quickly got some 10W40 semi-synthetic (I now know not to use that stuff), topped it up and continued my journey home. During that journey, I had passed a couple of trailers with a few mk4/5/6 Regals on them whilst I was on the M3.
I pulled into one of the local shops fairly near to me to get a few things then tried to restart it and couldn't. I soon realised that I needed to put my foot down to the floor to start it and rev out the hot petrol before it will run properly (I didn't know that at the time). I got it home without any problems.
This summarises how the car was:-
- No radio
- No interior light lens nor bulb
- No rear boot light
- Door cards painted in some horrible dark red nail varnish
- Slightly broken radiator grille
- Driver's window didn't wind up properly
- Carburetter breather routed incorrectly (it took me a while to find that one out) and float valve sticking. Other carburetter, head gasket and engine faults became apparent later on.
- Horrible sunburnt red mk1 Robin carpets
- Fractured rear tailgate locking plate (on the bumper) that eventually broke
- Front passenger's seat not attached to anything
- All of it's seats covered in blue fabric to hide the tatty driver's seat and the stained rear bench seat.
- Headlining slightly torn above the rear tailgate (that's still there but it's not really noticeable.
- Clock adjusted knob broken.
- Mk1 Robin speedo installed (I left that as it is)
- Rear of gearbox dripping gear oil
- O/S rear tail/stop light intermittently working (I cleaned that up with PlusGas and that's worked ever since)
The plastic fish on the rear tail gate and the green sunstrip on the windscreen were later removed.
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:09 am
More pics of how it was
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) Photo0078
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) Photo0079
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:10 am
Snowy Rialto November/December 2010
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0034
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0033
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0046
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:45 am
I had replaced it's rear gearbox oil seal and renewed it's propshaft bolts in October 2010 and that had stopped the gearbox oil leak.
Cylinder head gasket replacement and cylinder head "rebuild"
December 2010, January 2011
After a few months of finding out why my Rialto SE wasn't running properly, I did the following before I decided that it's cylinder head gasket and valves needed to be replaced (in no particular order):-
- Replaced carburetter float needle valve (the engine oil did stink of fuel at the time and replaced that immediately)
- Replaced carburetter main jet assembly (it was spraying fuel on the drip tray ! I can't remember when I replaced it)
- Replaced fuel hoses (I could only get 1/4" SAE J30 R6 at the time) as the other ones had perished and were leaking
- Replaced both fuel filters
- Replaced distributor cap, points, condenser, rotor arm and HT leads
- Changed the engine oil at least twice)
- Cleaned out overflow bowl
- Replaced air filter and spark plugs
- Replaced valve stem seals
So I decided to get the car into the garage and started to work on it. Engine bay how it was before I started to work on it:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0134
More details are on this thread http://www.reliantworld.co.uk/forum/showthread.php?25117-My-Rialto-Mini-Engine-Rebuild-(hope-it-s-just-valves)-Starts&highlight=
That was a start of a learning process for me, not helped by the very cold weather at the time. I got it up and running again (I think) January/February 2011.
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:48 am
Tidying up it's interior May 2011 (about 2 weeks before I got my Rialto 2)
The nasty looking interior as it was (I had installed the floor mats in it as the carpet was badly holed):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0166
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0165
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0164
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0163
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0162
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) 2010-09-19113636
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:50 am
The interior afterwards. I had bought some carpet roll and trimmed the passenger's side foot well and rear foot well carpets (not shown in the pics) and removed the nasty looking stains from the rear bench seat and boot carpet (not shown in the pics):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0178
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0177
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0176
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0175
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0174
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:52 am
The car's exterior as it was (after I had removed the tatty looking plastic fish from it's tailgate):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0158
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0159
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) ReliantRearDecal
....and afterwards
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0168
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0170
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:56 am
Engine bay tidyup and cylinder head (overdue) retorque, September and October 2012
The engine bay as it was. Cylinder head-block alignment looks good and there are no leaks Smile :-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0264_zpse68359a1
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0265_zps58646697
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0266_zps3bd77278
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0267_zps9a102199
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0274_zpsa7d8402c
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0275_zps73fff673
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0276_zps0dba863a
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 7:58 am
Incorrect standard distributor fitted to my Rialto SE's yellow top engine:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0269_zps9429ffed
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0270_zps973fc748
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0271_zps15167a58
Which I replaced (eventually) with the correct yellow top distributor after I had replaced it's knackered O ring:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0272_zpsf958e286
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0273_zps12f58539
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:00 am
Tatty air filter that was fitted to the car:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0279_zpsac7a03b1
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0278_zpsa497a7c0
....replaced with this one:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0277_zpse5539bbf
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:02 am
750 tappet adjusted fitted to the rocker shaft (the original 850 broke and I could only get a 750 one at the time):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0280_zps75c2bf39
....replaced with the correct 850 tappet adjuster:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0283_zps87c0c024
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:04 am
Rocker cover as it was (no nasty sludge in here Smile ):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0281_zpsff5f8fb9
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0282_zps1fed01fb
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0284_zpsf027e103
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0285_zps73a24a2f
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0286_zps0c841da1
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:06 am
Rocker cover being painted yellow as my Rialto SE has got a yellow top engine (it took me a few days to get it right):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0287_zps265f7f5c
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0288_zpsd4aa491e
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0289_zpsf3ac2e56
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0290
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0291
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0292
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0293
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:09 am
Rocker cover refitted...
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0294
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0295
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0297
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0296
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0231
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:10 am
Starter motor's battery live terminal as it was:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0232
....and insulated with self-amalgamating tape:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0233
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:11 am
Nice looking air filter fitted:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0234
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:14 am
Yellow top distributor fitted
New distributor O ring from SC Parts Group:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0235
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0236
Knackered old O ring:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0238
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0239
Yellow top distributor fitted:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0237
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:16 am
Driver's engine cover replaced
Old engine cover where two of it's screwholes become too large and the engine cover its self was cracked:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0253
Engine cover from eBay fitted:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0254
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Nov 05, 2012 8:19 am
Fuel hose brackets fitted (after the advice I got from str8lolly and Fifer)
I had a couple of original fuel hose bracket that I got from pop-rivet and wheaters (now fitted to my Rialto 2) and decided to fabricate two new ones from 20mm, 3mm thick stainless strip (I had to fine tune the ends of them with the bench grinder so that I can fit the clips). I also fitted new clips from Bresco:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0268
Fuel hose brackets and clips fitted to my Rialto SE (I had to fit the rocker cover bracket at an angle so that the fuel hose runs nicely). I also ensured that there were no tight radii within the fuel hose from the fuel pump to the carburetter:-
PostSubject: New (home made) HT leads that I decided to fit to my Rialto SE today...   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptySun Jan 27, 2013 6:05 am
I thought I would update my Rialto SE thread and have decided to make up my own HT leads today. I'll let the pics do the talking...
New Lucas DDB108B distributor cap (with brass contacts) from AES:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0117
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0118
Old Intermotor aluminium distributor cap that was fitted to my Rialto SE:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0119
This is the main reason why I wanted to make up my own HT leads. The number 1 spark plug end always falls off when removing the HT lead from the spark plug (despite recrimping it):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0120
Both sets of HT leads made up for both of my Rialtos:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0121
Both sets closer up:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0122
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0123
New HT leads fitted to my Rialto SE:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0124
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0125
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0126
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0127
PostSubject: Rialto SE road test. :)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Jan 28, 2013 12:30 am
I've just driven the same 12 mile route (mixture of smooth and fairly rough roads up to 60 mph) as I did with my Rialto 2 and my Rialto SE didn't have any ignition related problems either. Smile
PostSubject: Replaced washer jet, fitted new radio and speakers   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptySun Apr 28, 2013 12:27 am
A quick minor update. I have replaced the washer jet after I broke the old one after I unblocked it with compressed air and refitted my Rialto's new radio. I also used RTV silicone sealer to stop the windscreen wiper's wheel box and washer jet from leaking water into the car. Anyway, I'll let the pics do the talking.
New twin washer jet from Car Builder Solutions:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0313
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0314
New (£25 unbranded) radio from Amazon:-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0315
New Roadmobile RMS620 speakers (that replaced the Roadmobile RMS630 ones as they took up too much boot space):-
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0317
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0316
1989 Rialto SE Hatch - my very first Reliant (and I've still got it) IMG_0319
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyMon Jan 06, 2014 4:06 am
Since 27th April 2013 I have ended up replacing it's A frame last September to get it through it's MOT as the old one had snapped on it's rear tube next to the N/S mount.
I also plan to fit a front mudgaurd to it as it's never had one since I bought it and new wiper spindle bushes (as soon as they arrive) as the current ones leak on both of my Rialtos.
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptyFri Jan 10, 2014 8:24 pm
Fitted new wiper spindle bushes (yesterday)
Old outer wiper spindle bush and new PU seal to replace it (left hand side of photo):-
Old inner wiper spindle bush and new hard rubber suspension bush (yellow) to replace it:-
Outer wiper spindle bush fitted to the car (I've also fitted the inner one, but that's hidden from view):-
I also freed up it's wiper wheel box with DP60 (penetrating lubricant) and spray grease as it was full of muck.
PostSubject: Re: 1989 Rialto SE Hatch - my very first Reliant (and I've still got it)   1989 Rialto SE Hatch - my very first Reliant (and I've still got it) EmptySat Jan 11, 2014 5:41 am
Update:
It appears that there is still a minor leak on the wiper spindle. Sad I guess the next thing to try is a 16mm O ring between the two wiper spindle bushes to see if that leak will stop.
Page 1 of 2Go to page : 1, 2  Next
» Reliant Rialto/mk2 Robin windscreen wiper spindle bushes info - copied from Reliant World
» 1988 Rialto SE hatch aka Duck
» 1985 Lap Rialto 2 (hopefully a more concise version of it) - this may take me time to update it.
» Rialto axle?
» Reliant Regal 21E
