Reliant forum
The forum for lovers and owners of reliant
 864 BT2 engine change
View previous topic View next topic Go down
Goto page : 1, 2, 3  Next
AzzY
PostSubject: 864 BT2 engine change   Tue Sep 20, 2011 8:45 pm
Got BT in the garage and its now being worked on
Before removal of parts
ASH are supplying us with the silicone hoses, a couple more bits to come.
Pretty much everything removed from the top part of the engine.
Had a late start today so not much done, hoping to have the engine out and the other one in tomorrow, we'll see how things go. I have quite abit of work to do here and there but it should be good after bounce
View user profile http://www.bugville.co.uk
geoffnewblue
PostSubject: Re: 864 BT2 engine change   Tue Sep 20, 2011 10:00 pm
Your fuel pump seems to fit high up the block or is it just the picture
AzzY
PostSubject: Re: 864 BT2 engine change   Tue Sep 20, 2011 10:45 pm
Never noticed it lol, its just the picture, its the most recent pumps available and they do seem abit taller than the old ones anyway, because the distributor isn't in place it makes it look high up.
Admin
Admin
PostSubject: Re: 864 BT2 engine change   Wed Sep 21, 2011 2:45 pm
864? what have you done to make it like that?
View user profile http://reliant.forumotion.co.uk
AzzY
PostSubject: Re: 864 BT2 engine change   Wed Sep 21, 2011 6:09 pm
I've fitted oversize pistons +0.020
AzzY
PostSubject: Re: 864 BT2 engine change   Wed Sep 21, 2011 9:54 pm
The engine is now out
Have removed a few bits so far, got to get the 864 ready to go in now, more pics as I go along with things
AzzY
PostSubject: Re: 864 BT2 engine change   Thu Sep 22, 2011 9:52 pm
Didn't get much done today as had a family BBQ, did however get the engine out and have moved bits over, the other engine is now being stored. Ended up having to buy a couple of sets of feeler gauges as the old ones have been lost, but had past it anyway so not to worry! Anyway the dipstick was a pain in the ass to fit but that's now done and I hope it doesn't leak.
I changed my breather idea on the gearbox top and should work better now.
All the hoses are now in and the heat wrap so I guess I best get to work and get the damn things fitted.
Admin
Admin
PostSubject: Re: 864 BT2 engine change   Fri Sep 23, 2011 2:15 pm
looking good their azzy Very Happy
AzzY
PostSubject: Re: 864 BT2 engine change   Fri Sep 23, 2011 9:11 pm
Thanks mate clown
Spark plugs fitted NGK as usual Wink
Engine ready to be hoisted into place
Fitted and bolted onto chassis.
I had this problem with the original engine plate, the alternator fouled the plate on half adjustment, giving you no option but to change the belt, I finally decided to just remove some metal so the alternator now has 3/4 adjustment, if I need more I can remove more metal at a later date, but if the belt needs to go passed 3/4 I would rather scrap the belt.
geoffnewblue
PostSubject: Re: 864 BT2 engine change   Sat Sep 24, 2011 7:38 am
That's a good idea I shall have to check New Blues when the engine is out
AzzY
PostSubject: Re: 864 BT2 engine change   Sat Sep 24, 2011 8:53 pm
Started off the day with cutting the hoses to size and test fitting them, all went well
Hoses fitted and clamped down, certainly looks nicer compared to the usual rubber hoses
A new oil filter fitted, it just went round and round, I'm sure its suppose to go here as there is a hole underneath it so I glued it in place.
Due to the fan not being very effective I thought I'd try something, the top fan is fitted slightly round compared to the other one, so in theory it should act as a bigger fan.. I tested it just wiring it up and god it pulls some air through! Not tried it on the ducts though
A few more bits fitted.
A slight alteration to the gearstick, I've altered the underside slightly (you can't see it) and I used some silicone hose over it, feels nice and soft now.. Will make for some even easier changes
Also gave the link pipe a coat of paint
AzzY
PostSubject: Re: 864 BT2 engine change   Sun Sep 25, 2011 9:58 pm
On the way to picking up the nearly new cans we came across two of these beauties
A nice set of 6month old cans, these are slightly larger compared to the 916 can, but still the same fitments, I am putting my de baffled one to the side for now.
Got the headers back, game them a paint and wrapped them up good, I do hate wrapping, even xmas wrapping!
Carb fitted along with cables
Dist cap fitted, Vacuum line fitted, a few other bits fitted.. I started sorting the exhaust link pipe and can out to be fitted but I felt unwell so resorted to laying down lol.. Will continue tomorrow of course. After the engine is all done, have the rear brakes to sort out still ,also a few interior bits.
geoffnewblue
PostSubject: Re: 864 BT2 engine change   Mon Sep 26, 2011 7:34 am
Love how tidy under your bonnet looks Very Happy
AzzY
PostSubject: Re: 864 BT2 engine change   Mon Sep 26, 2011 8:05 pm
Thanks Geoff, I do try but sometimes I get lazy lol!
Fitted the rest of the hoses and a few other bits, the engine does run and sounds very nice, however I spotted an oil leak at the rear of the engine, turns out to be the seal, I have removed it and will be fitting a new one tomorrow and re-fitting the gearbox etc and then I can get on with the brakes. I shall attempt a video/sound at some point Smile
AzzY
PostSubject: Re: 864 BT2 engine change   Mon Sep 26, 2011 8:10 pm
The heater also works really well with the double fan Basketball
View previous topic View next topic Back to top
Page 1 of 3Goto page : 1, 2, 3  Next
» Change in Leadership
» eml mini jumbo with kx 500 engine
» POCONO DATE CHANGE
» Coaching Staff Change
» JBL Talks About How The PPV Industry Will Change Dramatically
Reliant forum  :: 3-wheeler :: Mechanics-
