Hey guys,
been running around in the robin and adding the miles but having a few issues with the clutch, So was wondering where does the clutch normally engage? I've got about an inch on the pedal (push from stationary to about an inch from the floor before it engages) so sometimes having issues getting into gears.
also have a problem with the Robin jumping out of second during engine braking.
and finally today I was coming from second to third and the Robin made a crunch noise and the gear stick locked up with no drive. so had to pull in and pulling the thing out of gear after that all gears worked fine.
