 TEMPERATURE GAUGE
Tony Guest
PostSubject: TEMPERATURE GAUGE   Fri May 01, 2015 7:17 am
The temperature gauge on my Fox reads hot but the engine is running at about 76 degrees C (tested). New gauge and temperature sender fitted - what else might be the problem? Voltage regulator?
PostSubject: Re: TEMPERATURE GAUGE   Fri May 01, 2015 7:27 pm
Incorrect tempurature gauge sender assuming that the fuel gauge is reading correctly.
Tony Guest
PostSubject: Re: TEMPERATURE GAUGE   Sat May 02, 2015 5:53 pm
New sender and new gauge fitted - still reads "hot" despite engine running at the correct temperature.
regal_fan
PostSubject: Re: TEMPERATURE GAUGE   Wed Jun 24, 2015 7:23 am
Voltage regulator the common culprit on these
tickerzoid@gmail.com
PostSubject: Re: TEMPERATURE GAUGE   Thu Jul 16, 2015 4:44 am
I don't know what you mean by tested but I did an experiment today whereby I checked the top of the rad and the rear cylinder head core plug with a laser temperature gun. With the temperature gauge in the middle I had readings of 85 degrees C on the core plug and 76 on the radiator. If you have the same then the engine is probably OK. I'm advised there is a small screwdriver slot in the back of the speedometer that is used to calibrate the temperature gauge.
TEMPERATURE GAUGE
Reliant Central  :: The Daily Mechanic-
