Having damaged the dashboard in my Fox as I took out and replaced the heater, a replacement was ordered (at considerable cost). On arrival it turned out to be worse than the one it was supposed to replace - I complained and was sent another - also unusable. I then repaired both but then realised the switches were different so I repaired the one I took out in the first place.
SO - 2x dashboards available £60 each plus postage (I would prefer you to collect in person - Notts/Derby area).
Will fit Robin, Rialto, Fox etc (but may need different switches depending on model).
